Easiest way to create a dxf of a wireframe from a camera position for artwork.
bdhowey
bdhowey
Hello, I want to create a .dxf (or other vector file) of a wireframe view from a camera position, but I am stuck trying to figure out the easiest way to do this. I think I could create a plane and project everything on to it and manually delete stuff but that seems like a lot of work. Is there an easier way to do this?
HughesTooling
Probably easiest to create a 2d drawing and export to DXF. In the design workspace create a named view that matches the view you want, then in the 2d drawing select the named view as the base view.
Mark Hughes
Owner, Hughes Tooling
