.dxf spline to polyline converter app
hi folks
ive downloaded the f360 app spline to polyline converter but now cant seem to fine it in the comand menu.
ive resarted f360 but still to no avail. am i missing some thing or doing things wrong?
jhackney1972
Go to your Tools menu, find the Add-In and see if it is loaded or needs to be select and run.  Some add-ins can be set to run when Fusion 360 is started.
Edit: From the application instructions, it would seem when it is running, will create a selection when you are in a model sketch it will appear under the Create menu drop-down.  The graphic from the instructions is from an old UI but here it is.
John Hackney, Retired
Hi many thanks I've managed to find and use the tool, unfortunately it's not done my job.
My plasma cutter still won't read it as there are still  splines. I think it's not doing a great job. Is there any other Options?
JeffreyArney
Thanks perfect.
