DXF Performance Issues
01:32 PM
Hi All,
I need to import DXFs for various items that I need to incorporate into a design. They are not complex by 2D CAD standards but F360 basically grinds to a halt as soon as I try and use them.
I have tried several of the suggestions mentioned in the forums already:
- Updating NVIDIA drivers. This took it from "F360 freezes eternally" to "F360 only takes 2-3 minutes to select sketch items after drawing a marquee" but most operations (move, delete etc) cause the program to stop responding
- Simplifying sketches. This is a marginal improvement which requires I delete critical parts of a design in order to make the software run well enough, which it still doesn't come close to.
- Hiding sketches. Yes, it helps. No, it still doesn't work well enough to use in an ongoing sense. I'm not sure how I'm supposed to lay elements of a design out when most of it is hidden.
The part that bugs me (pun intended) is that my 1.5 year old PC barely breaks 20% CPU and 15% GPU while doing this. Less than a quarter of my RAM is utilised. The PC does not appear to be running out of steam, as verified on a 13 year old machine with basically the same outcome when doing the same operations with the same files. So what's the hold-up? Am I unreasonable for expecting it keep up with DXFs that I've been using for 10+ years and never even considered performance?
