DXF Import Utility error
jimc33BAK
jimc33BAK
We are unable to import this DXF successfully without errors.  It includes an ellipse.  We are trying to use the DXF import utility.
jhackney1972
I tried to open your attached DXF in both AutoCAD and Fusion 360 and it failed.  Can you attach another copy that is valid.
John Hackney, Retired
jimc33BAK
The file was exported from a CMM running kodak. It contains an ellipse. If I leave the ellipse out, the file opens fine. In the past I was using turbocad to open the CMM files. We have recently switched to AutoDesk products. I'll have to see if it opens in turbocad. Maybe there's something wrong with the kodak export.
