DXF file with points doesn't import
I have a very simple DXF file with three points that I tried to import into a sketch.  The points don't show. I'd like to know if there's something wrong with either the DXF file or Fusion 360. I have attached the file test.dxf.
Thanks!
Jim
HughesTooling
InsertDXF seems to ignore points but uploading the DXF through the data panel will import them.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks very much for the suggestion.
The upload button is missing from the data panel - my project is open with a
sketch and has been saved, and I am online - the clock icon is showing
without the offline warning.
Do you have any suggestion for how to get the upload button to display?
Thanks again,
Jim
HughesTooling
Make sure you're not in the My Recent Data folder, you need to be in a project.
Mark
Mark Hughes
Thanks - my rookie mistake. I have uploaded the DXF but can't seem to get
the points to display. I created a new project, uploaded the dxf file, but
can't seem to get the points to be added to either an existing open sketch
or import as a new item. Getting close, though!
HughesTooling
When you open the file you've uploaded you need to zoom out, zoom fit doesn't seem to see the points. When you open the file it should have one sketch called points.
Mark
Mark Hughes
