There is a particular, weighty (2D) DWG file I'm working with in Fusion. Because of the constraints and whatnot, the file lags terribly. I try to delete portions I'm not using, and it lags for about 10 minutes per item.
So somebody mentioned cleaning it up in Illustrator first. Great. This seemed to work. However, on re-opening in Fusion, it has now separated each line segment into it's own object, which resulted in hundreds of objects.
I'd share a screenshot, but I don't think it's needed. I'm just wondering 1., if I need to do something addition in Illustrator first (which has hundreds of layers too), or 2., can I just group all the poly-lines in one object layer (within Fusion)?
Thanks!
