Drawing template BUG.
HughesTooling
Consultant Consultant
HughesTooling
I have a customer that needs 6 views of a part on separate sheets so I set up a template to populate 6 sheets using the 6 standard views available.
When I pass a component to the drawing workspace I don't get 6 different views. All I get are 2 sheets set to Top and 4 set to Front! See screencast.
Template is attached.
Mark
Mark Hughes
Owner, Hughes Tooling
paul.clauss
Hi @HughesTooling
Thanks for posting! I was able to recreate this issue with the wrong views being pulled into drawing templates in your file as well as in a new file and logged FDWG-10054 with the Drawing team to get this fixed.
We appreciate you reaching out on this one! In my tests, only the Front and Top views were pulled into the drawing templates, regardless of what placeholder view was created. The only way I found to work around this was to just create a new view in the Drawing.
Paul Clauss
Product Support Specialist
