Drawing sheet folder in modeling environment
Ok, I just started creating drawings from my models and I noticed there is no folder in the Modeling Browser for drawings!?  So I went to “Drawings Update & Roadmap – April 2017” and saw this, “We’ve made some big leaps in this area by releasing some meaty features like the browser & multi-sheet (can I get a hallelujah?!).”  Are they talking about the Drawing browser?  Or the Modeling browser?  And if it is the Drawing browser WHY?  … is there not a folder for drawings in the Modeling browser?
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for your posting! Smiley Happy
I think the browser meaning is to modify the model through the web browser without installing Fusion 360.
Here is the detail information.
If I misunderstand, please let me know.
Many thanks,
Ahreum.
cmiller66
Hi Rex,
By Drawing browser we are referring to this:
Previously once you created a drawing there was no way to edit the drawing to add/remove components.  Now for each base view we show a browser node in the drawing environment which allows you to include/exclude (from parts list), and show/hide components in the corresponding view and any projected views. We do not have a "Drawings" node in the Model (3D design's) browser.
What you could do to collect your drawings is create a Drawings folder in the Data Panel under your project and then save your 2D drawings there:
Otherwise the drawings (the f2d which is actually a separate file from the design/f3d) will appear in the data panel with the designs.
Not sure if that answers your question, please let me know.
Chris
Wow Ahreum,
 That is absolutely not what I was trying to figure out - BUT – what you showed me is - ABSOLUTELY AWESOME!
Thank you so much, Rex
Hey Christopher,
Your response did answer my question and give me way more info than I figured out myself at this point.  I’ve only just started branching out into the drawing environment.
I did start by creating a drawings file in my Data Panel but have since appended the names of my associated models for their drawing by adding a Sh1, Sh2, etc. to keep all info together in same folder.
I just figured that by having a Drawings file or “node” in the browser of the modeling environment of each part/assembly it would be so much easier and convenient to keep track of all files/documentation.
So thank you so much for the help, Rex
