Drawing Exploded View Not Updating to Match Model
alex_watsonFLLRJ
alex_watsonFLLRJ
Community Visitor
Community Visitor
I created an exploded view in the animation tab to be used in a drawing, the model in question contains a number of component files. When creating the view initially I realised I needed to edit one such component so that its bodies could be separated out within the view as well.
To do this I edited the file in question by converting the bodies to components within the same file. I could now move these 'components' independently within the exploded view, achieving the representation I needed. However, when switching over to the view on the drawing sheet the item remains unexploded within the drawing exploded view.
I have tried creating an exploded drawing of this file on it's own, and that works okay. I also tried saving it with a new file name and replacing the original in the overall assembly, but still the drawing view does not update.
Any ideas what the problem could be?
Alex
Pramod.kadam
Hi @alex_watsonFLLRJ ,
Thanks for reporting and apologies that you are facing an issue.
May I know if it is configured design or normal one? Are you able to create a new storyboard and place that in the drawing for same design?
It would be great if you could share the file to pramod.kadam@autodesk.com for better investigation.
Pramod Kadam
Product Owner
Fusion 360 Drawings
