Drawing Crashes or Freezes
MartinCrawford-DTLD
MartinCrawford-DTLD
It seems like every time I attempt to create a drawing, Fusion either crashes or freezes.
I can't seem to pinpoint what I am doing at the time, it seems after 15-20 mins of working in the module, it will either lockup or crash. I have managed to get the drawing complete, however it took me 4 hours instead of what should have been 15-20 mins of work.
We are somewhat new to using Fusion (about a year) and have never attempted to use the drawing module as the feature set was incomplete and it was not practical to create usable drawings. With the recent changes, there are enough features and flexibility that we would like to start using it.
My challenge is the stability and performance. With the number of crashes I have had on small drawing and the performance issues and the larger drawings, I'm not sure it will be a viable option.
Here is a link to a pretty simple drawing that seems to crash Fusion after 20-30 minutes of working within the file.
https://a360.co/3kbvHEt
Am I doing things wrong, or more importantly, are there things I should be doing to make the process more stable. I many other models that will crash the system.
Also, it seems the only way I can get Fusion 360 working again, is by restarting the computer. Is there something I can do that would reduce the number of restarts required. I try force quitting the AeCore, however that doesn't seem like it is enough.
Martin
g-andresen
Please create a screencast of such a process.
I can easily derive a drawing in seconds.
günther
suryawa
Hi @MartinCrawford-DTLD ,
Thank you for the detailed info that helped to understand the problem.
This crash/hang issue will be tracked through bug report FDWG-12804
I shall post relevant updates based on progress of this bug number.
Thanks & regards
Amit Suryawanshi
SQA Fusion 360
Amit Suryawanshi
SQA Fusion 360
