Hello all. I am a total newb that's just getting started with Fusion. I have successfully created a part in the regular Fusion environment. However when trying to make a 2D drawing with dimension some of them are not corresponding to the proper measurements. And yes I'm trying to dimension Orthographic view as the drawing I'm trying to make is so I have a print to work off of. What isn't specifically translating is an ID on a cylinder. The fusion program shows it correctly at .625" but when I use the "Dimension" tool in the create drawing section it changes it to .630". It does this no matter what I do. I've tried to use a 1:1 ratio and that doesn't work either. I've attached screen captures to illustrate the problem.
