Download problem
Download problem
Download problem
I would like to convert a step file into a sldprt file.
When I upload te step file into the cloud and than try to download it I do not get the option to make it a sldprt file.
I even get no option at all. The file just starts downloading straight away.
When I check the thutorials it shows me that there should be options.
Why don't I get the options to change the file type?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
I believe you are uploading the file to the Data Panel within Fusion 360, correct? If so, this automatically translates the part to a Fusion design so that you can immediately start working on the project. If you navigate to A360 (which is where the cloud data is stored and what the data panel is connected to) -  you can upload your STEP file here and it will not translate.
With that being said - there is no download option that we offer for .sldprt.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi James,
That doesn't solve my problem. I uploaded my stp. file directly into the cloud but when I download it then there in no choice to download it as a other file. On my computer you see that if u push on the download button there is no choiseOn my computer you see that if u push on the download button there is no choiseOn the computer of a other user he does get the choise to pick a other fileOn the computer of a other user he does get the choise to pick a other file
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I guess I am a little confused. Does the drop down not show up for you? Whereas it does for another person? Can you try using a different internet browser? Does that clear the issue up?
James Youmatz
Hi James,
Yes, that is the problem. I just tryed it on firefox but still like on chrome the drop down doen't show up.
Do you have a other solution?
Toon
James?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Sorry for the delay. One thing I can think of - if you open an incognito browser (or private browsing window) and use a Shared Public link to download, do you see the options?
Does this happen to all files that you try to download?
James Youmatz
