Doubled up material
Doubled up material
nClarke0101
Doubled up material
nClarke0101
When i drag a item from my data panel, and break the link, it duplicates the used material in the projects Physical Material.
Is this normal even if they are the same base steel material?
It wont let me delete the duplicated one. (they both have the same name and same properties)
pawel.potyrala
Hello @nClarke0101,
thanks for posting! Is the duplicated material one customly created by you? Does any error report pop out when you try to delete it (if so, could you post a screenshot of it)?
Thanks a lot in advance!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
nClarke0101
Hi.
Nope its the standard steel, just made new test items and it does this.
I dont change any material settings.
happens when you drag in a item in then break the link. check the materials of the main component and it shows it has 2 steel materials both cannot be deleted/removed
