Don't save without prompting me first
ltomuta
Advisor Advisor
ltomuta
If I open a design just so that I can export it, yet before the actual export Fusion notices some changes in the file that are not yet saved, I should be the one deciding whether I want the changes saved or want them discarded.
HughesTooling
Have you tried unchecking Automatic version on close?
Mark Hughes
Owner, Hughes Tooling
g-andresen
place your cursor at the point with the desired state in the timeline
günther
HughesTooling
Sorry, misunderstood at first. I think I see the problem, if you want to export to a file type that needs the cloud translators you are informed you need to save. What file type are you trying to save to? Only workaround would be to save a copy then export the copy, that's what Fusion would need to do as the version on the cloud is out of date.
Mark Hughes
