doing some trivial - seems impossible.. create a line, change how long it is wit
Ok, so you create a line tell it it is 9" long, duplicate it up 25mm, draw an arc on each end....
Now, the impossible task... Change that 9" to 100mm... OMG that is freaking IMPOSSIBLE. You might say, just hit 'd' and apply a dimension, but you have to delete the other one first, and I can see little circle/bar indicators in the corner (and if I delete them they go grey, but otherwise make no difference), and then I add a dimension, and I have to delete the previous one. Now, someone who actually had done usability, would have put up a message that said: "you must delete the existing dimension, would you like me to do that for you? Or, Here is how to do that? or would you like walked through that process?
So far, everything I have done that is simple in Fusion 360: select two objects, align centers (duh) - I have to draw construction lines to create a midpoint and then align to that midpoint, or center one object inside another one (I do this ALL the time - apparently, by creating two construction lines for each one that gives you the midpoint, and then aligning the midpoints.. (isn't the a constraint to align one object to the center of another?)
In any event, I'm trying to select an object and shrink the width... in under an hour, so far, I've not been successful... I've managed to get it to resize ONCE one of the two lines I need to resize. What do I want to do? Just select the object, get a <> resize cursor, and resize it.. Sure, it would be cool if it prompted me for the exact size, but I'm just fine with select about 100mm of the 9" that it currently is.. Well, 10" as there is a 25mm diameter arc on each end..
It's fusion 360, complex things are easy, and easy things are complex.... (I can make a vase in under 5 minutes, or even create an extruded component in a few minutes... but resizing a line? Hours so far.. Easier to just redraw everything... every time... That is how I did my last few sketches... select old line, draw new one to part of it, and delete old one... but OMG this is getting old!
(and preview on this page does nothing, I hope post does something!)
