Documents stuck uploading
brentd27
Observer Observer
brentd27
Observer
Observer
I have two documents that are stuck uploading.  In both cases, I originally created the document on my laptop, saved, the document and closed 360, then closed the laptop, and later tried to reopen the documents on my desktop.  I ended up having to recreate them as they show "Document still uploading" on both machines.  I have tried everything I've found online to clear the download cache on both machines, but they come back as soon as Fusion is restarted.  Any ideas how to fix it?
RajkumarIlanchelian
@brentd27
Do you have the personal license? If so can you try this solution? https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
If you are not on a personal license can you follow this document? https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/File-stuck-in-uplo...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
