Document management menu appears blank
matiazVENU7
matiazVENU7
Hi
I'm using Fusion Personal, and the document menu appears blank, as you can see in the screenshot.
As I have reached the limit of documents, I cannot use the program any more (as I cannot set documents to read-only / editable).
I've reinstalled the software and cleared cache, but the issue persists. Any help is appreaciated.
Mat
john.koerner
Oftentimes this is a graphics problem.  Try some of the graphics solutions in this KB article: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Data-Panel-is-show...
John Koerner
matiazVENU7
Thanks! The solution was similar to the proposed in that thread.
I had to set the Qt Rendering Hardware Interface API (Preferences > Compatibility & Troubleshooting) option to OpenGL, and it's working just fine now.
