Document is still uploading...
Unbekannt353
Message 1 of 30
Unbekannt353
Hello, i am having similar issues to other members in here, however have not been able to fix it.
I am using fusions personal edition and am thus limited to 10 editable files. This wouldnt be a big issue if i had more than that, but while trying and failing to save my document yesterday night, i am today left with 8 files which are saying that they are still uploading. (unable to open or click)
files were created when trying to save a document which kept erroring due to locally linked files (which werent local? and have not presented issues in the 75 revisions before this..)
I have thus far tried the following without success:
Job Status
tried clearing the job status, job status list is empty
Updating Fusion
ive updated fusion to the latest version
Offline Mode
entering offline mode and or restarting did not solve the issue
Clear Cache Data
tried clearing the cache data both online and offline
Checking for the files online in web
tried checking to see if the files are present online (and maybe deleting them there)
files arent anywhere but on my local machine.
following: https://help.autodesk.com/view/fusion360/ENU/?caas=caas/sfdcarticles/sfdcarticles/File-stuck-in-uplo...
  • Text Command to remove the upload que
command ran successfully removing 0 from the que.
  • Manually clearing the upload que
following the guide deleting/moving files still left with the same que.
I have also tried this without success
-Launch Fusion
-Go Offline (manual switch)
-Close Fusion
-Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file
For me there is no "Options" folder
-Launch Fusion
-Editable Document list should be empty
EDIT (it was in appdata not local, i found it):
renamed to _backup092024 for now, opening fusion 0/10 editable documents, documents are gone.
entering online mode again, they returned.
theres probably more that i tried however i may have forgotten by now.
attatched are the logs.
Replies (29)
Message 2 of 30
RajkumarIlanchelian
@Unbekannt353 Can you please try the below?
  • Launch Fusion
  • Go Offline (manual switch)
  • Close Fusion
  • Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file (OR) \AppData\Roaming\Autodesk\Neutron Platform\Options\<user ID> login__ActiveDocuments file
  • Launch Fusion
  • Editable Document list should be empty
  • Mark a single document editable
  • Go Online
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 30
Unbekannt353
that worked, thank you so much for the quick reply!
Message 4 of 30
dustbuster7000
I had the same problem this morning and this resolved my issue also. I just added "_OLD" to the end of the active documents file mentioned above and program generated a new "login_ActiveDocuments" file to replace it when I booted it up.
Thanks.
Message 5 of 30
jveigli63
Community Visitor
Community Visitor
This worked for me too, after I had tried everything that was listed above and finally this worked. Thanks so much!
Message 6 of 30
timo_helmstetter
Observer
Observer
This didn´t work for me. I performed all the steps. But Fusion won´t launch without connection. So I need to reconnect to launch Fusion. Now I have 3 instead of 2 documents uploading. One with name, two without.
Message 7 of 30
timo_helmstetter
Observer
Observer
Edit: was wrong understanding of "manual switch"
Now my list is empty!
Worked for me!
Message 8 of 30
jtennant59
Community Visitor
Community Visitor
THANK YOU! THANK YOU! Solved my issue when nothing else would. You Rock!
Message 9 of 30
rick3VBYE
Community Visitor
Community Visitor
It worked! (Must click View/Hidden items in file explorer first. login__ActiveDocuments is hidden) Thanks!
Message 10 of 30
mojothesandman
Hello, I have followed this but then get stuck as there is no options folder after the neutron folder but then the options folder is not there .......
Message 11 of 30
RajkumarIlanchelian
@mojothesandman Can you please confirm if you looked for it in both locations? Also do you have the personal entitlement?
Autodesk Fusion
Join Fusion Insider
Message 12 of 30
itscristyyy
Observer
Observer
OMG THANKS! I was stuck with 3 editable documents. Didn't get anywhere with my support case, tried ALL the steps. This is the only thing that worked.
FYI in case anyone is using a Mac and looking for the AppData folder:
  1. Open Finder from the Dock
  2. Click Go in the menu bar
  3. Select Go to Folder
  4. Type ~/Library/Application Support and press Return
Message 13 of 30
rickbeec
I will buy you, Sir, a beer, coffee or Tea if we ever meet. Thanks!
Message 14 of 30
whyismydogfat
Community Visitor
Community Visitor
how do i do this on mac?
Message 15 of 30
RajkumarIlanchelian
@whyismydogfat Please update to the latest Fusion 2.0.20508 and then follow this document - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
Autodesk Fusion
Join Fusion Insider
Message 16 of 30
audieHCTSN
This worked for me. 5 out of my 10 allowed documents were in this state. For those who may not know the appdata folder is hidden by default and must be unhidden. Big thanks from the Big Island of Hawaii, and I want to express my gratitude to Autodesk for making Fusion available at no cost to those of us who could never afford or justify a commercial license.
Message 17 of 30
topshagy
Observer
Observer
Same problem here. But mine keeps crashing and won't save any changes. About to bail on fusion. This is a joke. Losing days of work.
Message 18 of 30
RajkumarIlanchelian
@topshagy Certainly seems like there is more going on here than just the documents. What version of Fusion are you on? Did you try the steps that I have posted in the earlier threads?
Autodesk Fusion
Join Fusion Insider
Message 19 of 30
topshagy
Observer
Observer
According to fusion i have the latest version. Tried updating just in case. Said I'm up to date. What's really happening more specifically is, any body I touch ends up gone without a trace when fusion crashes. And you know it does this alot. I manually save regularly as well as have autosave on every 5 minutes. I'm worried I may have exceed a limit. I have created over 1800 bodies in this design. And the timeline is very very long, almost 4 years on this . This design compared to others I have is much slower to open , save or make changes. Hangs up frequently and crashes more often. That I can usually handle. But this losing bodies and hours of work stuff is killing my motivation to continue.
Message 20 of 30
topshagy
Observer
Observer
##-Please type your reply above this line -##
