Distance dimensions in Recangular pattern are not remembered if referenced
sparky.summer
sparky.summer
Distance dimensions in Rectangular pattern in Sketch mode are not remembered as reference to a User parameter, by writing the reference parameter's name in the Distance value box. Instead only the value of the user parameter is recorded, after clicking OK button. The workaround is to write the reference name in Parameters table as a value to the desired parameter. Please, correct this.
g-andresen
please show this behaviour in a screencast and share the file
günther
Important:
Patterns should be created from features rather than sketches.
Only one instance is defined in the sketch.
sparky.summer
After resketching, the issue disappeared.
