Dissociated Association
tedbradley314
tedbradley314
In drawing mode, I create a linear dimension between two known points on the drawing. It says it's a dissociated association. This happens is about half the drawings I create. See attached.
tedbradley314
here's another example
tedbradley314
in the last example, you might say that it happened because i'm trying to dimension across two views. not so. here's a dissociated association with dimension on the same view.
jhackney1972
In this particular example, you are not zooming up close enough to pick the tangent point of the slot rounded end to straight slot wall.  You can also add sketches in the model and bring them over for slot center lines.  Screencast will illustrate.
John Hackney, Retired
ClintBrown3D
Hi @tedbradley314
I've replied on the other thread that you started, as I feel these issues are related.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
tedbradley314
Thanks John. I didn't realize I could make sketches visible in the Drawing mode. I'll try that.
I've attached the original 3d model.
I still believe that, in general, Fusion 360 should not allow you to select "recognized" green-symbol points on your model, dimension them, and then immediately call them dissociated. Dissociated dimensions should occur only if you remove the feature source of the selected dimension end point in the 3d model, IMHO. That's what I would call a "user experience bug".
