Message 1 of 9
How do I display the dimension of an extruded surface in a 3d view. Use case:
1) I sketch a rectangle 80mmx90mm
2) I offset the rectangle by 2 mm
3) I extrude the sketch by 80mm
4) I select the sketch and select the show dimensions option
5) Go to 3d view , i can see the height and width of the component
6) I can measure the component's extruded length using the inspect function
7) How do I display that extruded length in 3d view
See the attached images - First is what i get , 2nd is want i want to show
