Display window losing high order numbers
agareau
Message 1 of 1
agareau
I believe that there is a bug in the "Display" routine, in "Sketch" with the "Center Rectangle" command.
When the value goes above 99.x mm, it loses the hundreds position, ie : 118 mm is shown as 18mm.
However, if you persist and enter 118mm, the proper position is taken up, that is 118 mm.
Also, it would be nice to have the "Chamfer" command along with the "Filet" command in the "Sketching".
Replies (0)
