Dimensions are not showing up.
ryanmagid
Message 1 of 10
ryanmagid
I can't seem to get any dimensions to display. I have reinstalled Fusion twice but I can't see dimensions ever since Fusion did an update. I can see dimensions when I first draw the sketch but never again. I have show Dimensions in the Sketch Pallet but it doesn't do anything. I am connected online and do not have any update errors. I am fairly new to Fusion so I might be doing something wrong but I can't figure it out.
Replies (9)
Message 2 of 10
g-andresen
pleas share the file.
File >export > save as f3d on local device > attach to next post
günther
Message 3 of 10
Rohan.bongale
Could you please share the f3d, it will help us to better understand what is the problem?, I am not able to reproduce this issue.
Regards
Rohan Bongale
Message 4 of 10
TheCADWhisperer
What operating system are you running Fusion on?
What happens if you disable 3D Sketch?
Does the behavior persist in a new file - or only in this file?
Message 5 of 10
ryanmagid
@g-andresen Added the F3D file
Message 6 of 10
ryanmagid
Added F3D file.
Message 7 of 10
ryanmagid
Windows 10. It happens in all files. I just tried to make a new file and I can't see anything. Last time I used Fusion was about a month ago and I had no issues.
Message 8 of 10
g-andresen
Dimensions do not appear automatically but must be created.
günther
Unfortunately, it was not possible to embed the GIF, so it is in the attachment.
Message 9 of 10
ryanmagid
Thank you! I have been modeling in Maya and 3DMax for 20 years but am still new to Fusion. I don't remember having to add the dimensions in the last file I made but I must have. Thanks for the GIF!
Message 10 of 10
richardlaney
Hi, Dimensions are not showing up when zoomed in. I am trying to create a base template referenced from an pre existing drawn file, on one plane. When in 'top' mode I can use the dimensioning tool to see the dimensions between two points but if I zoom in and make a dimension point and then go to the next place and make the second dimension point, the dimension line appears but no box shows up showing the dimension and or giving me the option to change the dimension, which is what I need to put the template into the right dimension. This wasn't an issue for around 6 hours of using Fusion 360 but for 3 days now, I cannot get it to bring the dimension box back up when I have zoomed in whilst dimensioning.  I have clean re installed Fusion, upgraded to the lattes Mac OS operating system and still the problem persists.
