Dimension to midpoint BUG
HughesTooling
Consultant Consultant
HughesTooling
Normally you can dimension to the midpoint of a line by holding the Shift button down. What I noticed is if you apply a midpoint constraint between 2 lines first you can no longer select the midpoint for a dimension using shift. The midpoint is still selectable with a point but the dimension tool does not see it.
Mark
Mark Hughes
Owner, Hughes Tooling
saito.kh
Autodesk Support
Autodesk Support
Hi @HughesTooling,
Thank you for reporting this.
I recreated this behavior on my end with this update (R2.0.4343).  I've logged a bug with our development team for the further investigation.  (internal reference ID: FUS-42142).  Once I hear back from the team, I will update this thread to share the information.  I apologize for any inconveniences this may cause you - we appreciate you bringing this to our attention!
At this time I might create a point object at the location where midpoint was constrained and try to create a dimension.
If you have any questions, please let me know!
Thanks.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
