Dimension Depending is moving in the wrong direction
Message 1 of 20
Hi
If have a strange behavior. If i set a dimension on a existing sketch the dimensions moving in the wrong direction. I dont see the reason and because of the depentions i cant move it in the right direction anymore. How i am able to solve the problem or what i am doing wrong. The result is calculation right but not my itention. How i can force the line going in the itented direction.
Screencast:
1acb7fac-b5d2-4751-9135-fcb61560d31e,640,620
Replies (19)
Message 2 of 20
I think i found the solution by my self. I can fix points. So they unable to move. If i fix the right points the direction of the dimension is moving in the right direction. Please answer if there are any other solutions.
Edit: Its only a temporary solution. If i lose the fix, all following makings of dimensions are doing the same effect.
Screencast:
https://knowledge.autodesk.com/de/community/screencast/e8bd7aae-b14e-4ff5-9f41-a4d215329c80
e8bd7aae-b14e-4ff5-9f41-a4d215329c80,640,620
Message 3 of 20
TheCADWhisperer
I have seen this behavior frequently in Fusion 360.
File>Export and then Attach your *.f3d file here so that @jeff_strater has another example.
Message 4 of 20
jeff_strater
yes, please.  Share the model.  Thanks
Jeff Strater
Engineering Director
Message 5 of 20
Thx, for the answers. If i am export the single part the problem disapears. The problem is only there if i being open the sketch within the construction. I think its an problem with a dependency with an other part of the construction. I will provide the whole construction. One of the problem is within the sketch of "MonsterMittelDeckelLinks" Part. Try to change the dimention 122mm.
Message 6 of 20
jeff_strater
@Anonymous - thank you for sharing the model.  The behavior is quite reproducible, and I'll send it to the sketch team to take a look.
the Fusion bug is:  FUS-65558
Jeff Strater
Message 7 of 20
gdcm1964
another newbie question. I'm having the same issue. I want the line below the red arrow to move down in the dimension setting but the bottom line moves up.
What am I doing wrong? 🙄
Message 8 of 20
g-andresen
1. create a relation to the projection (magenta) or create one to the body edge.
2. Bring the two vertices to the same height.
günther
Message 9 of 20
gdcm1964
thanks for the reply but..I'm brand new to fusion and have no idea how to create a relation or constraint.
Message 10 of 20
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the post.
günther
Message 11 of 20
gdcm1964
I should have checked here before I deleted it.
I'm going to start from the beginning again. when I get to that point I will share the file. 🙂
Message 12 of 20
g-andresen
maybe the screencast will help with the next action
günther
Message 13 of 20
gdcm1964
my apologies for the late response.
I've started the entire thing over about 6 times to finally get to where I will be starting the lid again..
I've watched your video a couple of times but if there is audio I can't hear it.
Message 14 of 20
g-andresen
there is no audio but some callouts for better understanding
günther
Message 15 of 20
gdcm1964
Well I managed to get past that issue on attempt #2..
then this happened. I think I figured out why..the origin is on the very edge of the feature and it should be in the center.
Can I move the feather to accomplish that?
Message 16 of 20
g-andresen
günther
Message 17 of 20
gdcm1964
I thought I save it but I didn't.
I'll recreate it later today and post it.
Message 18 of 20
gdcm1964
I "think" I know what the problem is, I just don't know how to fix it.
In Lar's video his origin is in the middle of the lid. Mine is off to the side.
Message 19 of 20
g-andresen
Replace your plane 1 and select symmetrical extrusion
günhter
Message 20 of 20
gdcm1964
thank you for taking the time to do that.
I managed to get it in the right spot eventually using the mid plane tool but I will try it this way as well...a guy can't have to many options. 🙂
I managed to do this project tonite as well...
I must say I'm having a lot of fun learning how to use this program..
what is the secret here to get pics to show instead of a link?
