Detail view shows parts outside the circle
Robert-FreEnergy
Robert-FreEnergy
I have a detail view of a section view in a drawing.
There is a part visible in the detail view that is outside of the detail view circle.
If I manually hide the part, it remains visible.
If I update the model and then update the drawing, it remains visible.
This model is really big, so doing anything is painfully slow, it has taken 8 hours just to do this page of this drawing.
Any help would be really appreciated.
jhackney1972
You did not indicate, in your screen capture, the part(s) that are included but should not be.  Is the model over 71 MB? If not, please attach the model.
John Hackney, Retired
Robert-FreEnergy
The model is much bigger than 71MB sadly.
If you take a look at the drawing you'll see that there is a horizontal section protruding from the left side of the detail view, this is a part that is behind the green  cladding and thus not actually visible within the circle boundary of the detail view, which makes it even more bizarre that it is visible outside of it
-KyleWilliams-
Hey @Robert-FreEnergy
Are you able to share a copy of your file with my kyle.williams at autodesk.com? This way we can investigate further.
In the mean time its possible a refresh of the view may help. Try changing the Style or toggling on the Improve View Quality.
Kyle
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
Robert-FreEnergy
Would you like me to share the original file or the drawing?
Robert-FreEnergy
Hi Kyle, thanks for the advice, I've sent you an email with links to both the drawing and the model.
Sadly, changing the style and toggling the improve view quality button haven't solved the problem.
