desing is transparent and i cant make it filled again
temujar
Observer Observer
temujar
Observer
Observer
i desinged a piece and everything was ok in the start, but when i decided to try out a button command ctrl+/ the desing went transparent and i cant return it to the way it was. I have tried turning the opacity and the active component visibility but nothing helps. Is there just some command or tab i need to check?
g-andresen
check your display setting
günther
temujar
Observer
Observer
Thank you so much!, i have learned by myself to use fusion and this was first time this happened and i was getting desperate to get the design as it was.
