Designs will not be linked
mikeYEAME
mikeYEAME
I am a hobby user. Following the move to teams when I try to insert a design as a component into another design in the same project folder I get the message "Designs inserted from another hub will not be linked. Components from the selected design will be copied into this design" This happens even when I have started the component from scratch. I would like to be able to maintain the ability to maintain the designs , is this possible? Mike
RajkumarIlanchelian
@mikeYEAME Please run the below workaround and that should address the problem.
  1.  Close fusion
  2. Go to - C:\Users\kumarpra(use your id)\AppData\Local\Autodesk\Autodesk Fusion 360
  3. Back up folder Autodesk Fusion 360 and then delete this folder
  4. Go to -  C:\Users\kumarpra(use your id)\AppData\Roaming\Autodesk\Autodesk Fusion 360
  5. Delete folder Autodesk Fusion 360
  6. Relaunch fusion
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
mikeYEAME
Hello The workaround worked great Thank you
MrB0t
Worked for me too. Thank you.
The.Justin.Gibbons
Worked perfectly. Thanks.
Thole01PUZ3C
Observer
Observer
Worked Flawlessly. Thanks.
littlenyancat204
Also worked for me, although I'd prefer that Autodesk didn't force workflow-breaking changes on their users...
