Designing an ATX PC Case
aidanvillacampa
aidanvillacampa
I am planning to 3D Print a sick gaming pc case that ensentuates the RGB lighting found in the case. I'm planning on cnc cutting acrylic and making the case mostly clear. I am planning on 3D Printing, I have a pretty big printer (500x500mm), and I want to print the pcie slots, motherboard slots, screw holes, motherboard tray area, and such. I am wondering how I would go about designing this, I have a pretty good ammount of expierence with this software, but this seems like a hard project. Could anyone point me to some templates for the ATX and pcie cards. I tried the DXFs from protocase but they wouldn't work. I posting this so anyone could contribute ideas and collaborate.
Thanks Everyone,
Jedisintraining2
tallisb
Hello-
I recommend you take a look at Grabcad.com.  It's a huge repository of 3d models that people have made.  You can search for PCIE Card or ATX, etc.
https://grabcad.com/library?page=1&time=all_time&sort=recent&query=pcie%20card
Brad
Brad Tallis
Fusion 360 Technical Specialist
leowarren34
As cases go I wouldn't 3D Print large amounts of them.
The only component that is really limited is the motherboard but ATX is a really well-defined standard a quick google can bring up the drawings. I'd also recommend using a metal backplane for the Motherboard as components such as the VRMs will get very hot and a melted case won't be super functional.
As for everything else it's up to you where you lay it out. Acrylic is definitely an option if you can get a hot wire strip heater so you can get really nice bends. There are a couple parts you could 3D print but layer height is a concern.
I would think about how you are going to lay every component out, then design around that.
Are there any cases that you are using as inspiration?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
