Design wont save due to local file
chance_hogelie
chance_hogelie
First time I've had this particular issue on Fusion with not being able to save my design. I haven't changed anything in my build process so it is a confusing error to be happening over and over again even after removing components that I inserted into the design. I don't really want to break the link on the inserted components if I don't have to, unsure if that will fix it or not doing that method.
I went through the issue in the screencast so check it out and see if it makes sense
This is the error I'm receiving when I try to save:
Error: [CFS] Save of the cloud file RAM DECK welding deck v1 is aborted because it is referencing a local file Alumareel Air hose reel v0
dsouzasujay
Hi @chance_hogelie,
Sorry to see that you're facing this problem.
Please follow below steps to fix the problem
  1. go to below folder location
    • C:\Users\[YOUR USER NAME]\AppData\Local\Autodesk\Autodesk Fusion 360\[UNIQUE OXYGEN ID]\W.wwwwip1fqa
  2. Take a backup of 'F' Folder (Copy the F folder to different Location)
  3. Delete all the files and folders in "W.wwwwip1fqa"
  4. Restart fusion and see if the problem got fixed
If the issue still happens, then please send us complete log files
You can collect them from
  • Help -> Support & Diagnostics ->Diagnostics log files.
  • This will generate a zip file that you can upload.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
chance_hogelie
That worked! Thanks! I inserted one of the components into the design and I was able to save it. If it happens another time ill try this method again.
