Design not opening.
Design not opening.
tlk977042
Design not opening.
tlk977042
Community Visitor
Community Visitor
I made a design we are using for a construction project at home. I made this design approximately 1 week ago, saved it, and closed fusion. Today trying to open it, I get the following message.
RajkumarIlanchelian
@tlk977042 Do you work on multiple machines? IF so on both machines can you make sure you are on 2.0.19994? (also any possibility you are on Fusion Insider program and used that to save this file? If so the file is saved in a newer schema than what it is in production and is not backwards compatible ).
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
