design history before configure index wrong
rangorino
rangorino
I've tried out the configure workflow, which is a great addition, however it has kinda broken a design, so I have to revert to before.
So in reverting, I went back to the latest design that was (according to the version history) not a "configured" design. However, the last "non-configured" design was in fact "configured". I had to go back one more. Slightly confusing at took some time to figure out.
Besides that, It is not possible to promote a version from before "configure" was enabled, which is surprising I think.
rangorino
Weirdly, I have a parent assembly containing this problematic file, and the assembly is also configured, however the assembly does not exhibit this behaviour.
karina.harper
Autodesk Support
Autodesk Support
Hi @rangorino
Thanks for bringing this up. We are working on this issue - FUS-137933 - it happens when you have created a Milestone in the CD.
I added a note to the ticket referencing your post - thanks for flagging it!
Karina
Karina Harper
Software QA Engineer, Fusion
What's New in Fusion | Contact Support | EDU Support | Support Board Best Practices
florian.pflugfelder2QMSF
Dear Karina,
thanks for working on  that. I am also implementing the Configured Design in our Designs and i find it´s a great opportunity to decrease work and parts. But it seems actually there is a buck in the versioning. I have 3 different versions for the same part as you can see on the pictures.
Also the comments of the Version in the Drawing is different (repeats always the same "Kegellänge 8.5mm --> 9mm (weil zu früh angeschlagen)").
Could you please add that to the flag?
