Design changes do not accurately get updated in Drawing
robert8WJZ8
robert8WJZ8
I made a simple sketch with a few holes and extruded it. Saved. Moved from 'Design' to 'Drawing' /from Design. Manual. Created 3 views. Saved and Closed. I then edited the one of the hole diameters. Saved. I then opened the drawing and got a message "Changes have been made to a referenced design. You can update the drawing from the button in the Applications Bar." After finding the new button of a 'yellow chain' to the right of the Re-do button, I clicked on it. The result was that my 3 views were replaced with red boxes with nothing more. What did I do wrong? Am I supposed to do something with these red boxes?
jhackney1972
Please attach your MODEL only so the Forum users can test.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
robert8WJZ8
Done.
macOS 14.3
jhackney1972
I do not see the error you describe.  I am using a Windows 10 operation system but I do not have any idea that is causing your error.  The Autodesk developers will probably be asking you to record a video to show your process and error so you can save time by doing that now and posting it.
HughesTooling
@robert8WJZ8 Can you export the 2d drawing and share here? You'll need to download from your hub as an f3z file.
One thought is did you make sure the timeline marker was at the end of the timeline before saving the design?
EDIT. After looking at the design you shared I've answered my question. You need to roll the timeline to the end.
At the moment only the first sketch would shown in the the drawing.
With the timeline rolled forward.
Mark
Mark Hughes
Owner, Hughes Tooling
