deleting a referenced parameter leaves broken references without warning
maker9876
maker9876
In a sketch, if you delete a referenced parameter (eg line = 90mm long) then references to that parameters remain as they were (fx:90mm) even though a popup warning was generated.
This seems wrong. Should't those broken references turn yellow? Or perhaps just drop the "fx:" and become simply fixed "90mm" to follow the above example?
jeff_strater
@maker9876 - no, this is as expected.  Though you have deleted the dimension, the parameter is still preserved in the system.  It just becomes a standalone model parameter that is no longer tied to sketch dimension.  This preserves the model design intent.  I think you would not want the behavior you describe, to be honest - it would create lots of design errors
Before:
after:
Jeff Strater
Engineering Director
maker9876
That makes perfect sense.
The scenario I encountered was simpler: the reference was within the design itself and didn't involve parameter variables.
As below in the first square one side is set to 10mm within the sketch, the next referenced to it directly (by clicking on the 10mm).
When, in the second image, the 10mm is deleted the fx:10mm remains. That I thought was confusing because it's not referenced to anything. But was more worried that if there were several such mentions scattered around the sketch would soon lose track of what was referenced and what was not and wouldn't know where to start correcting. Then would make assumptions that things had updated when they hadn't.
jeff_strater
"The scenario I encountered was simpler: the reference was within the design itself and didn't involve parameter variables."
What you describe is exactly the same scenario as I had illustrated above.  When you created the second dimension and "referenced to it directly (by clicking on the 10mm).", you were, in fact, setting up this relationship to the parameter of the first dimension.  The example I created was the same, other than I had also added a "*1.5" so that the second dimension was not the exact same value as the first.
Jeff Strater
