Delete key (del) does not open menu
Themeepclub
Themeepclub
Pressing the del key on my keyboard doesn't open the delete menu. Selecting an object and pressing delete works but I'm trying to open the menu that allows me to select multiple items and delete them. Does the keyboard shortcut for the delete menu work for anyone else out there? Or is the delete function only supposed to work once an object is selected.
paul.clauss
Hi @Themeepclub
Thanks for posting! The delete key is not a shortcut for a command in Fusion - there is not a delete dialog box or menu in Fusion 360. The delete key will simply deleted any selected entities.
For multiple selections, you can hold down the CTRL key ((CMD on Mac) and select multiple entities to delete from either the model visualization or the browser tree.
I hope this helps clarify this! Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
jodom4
Selection Filters will also make your life easier if you're trying to select / delete multiple entities: https://www.autodesk.com/products/fusion-360/blog/quick-tip-object-visibility-selection-filters/
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
