Defining rectangle corners with vertices or construction points
paulGJCBP
paulGJCBP
I want to create a cabinet with panels in a groove. I am trying to create a rectangle to extrude into a panel to fit into an existing groove.  I want to use the corners of the groove cross section as two point defining the rectangle sketch.  The plan was to extrude that rectangle down the length of the groove.  I define the plane of the rectangle at the end of the groove cross section but instead of snapping to the vertices of the rectangular grove, the cursor remains free floating. I even tried creating construction points at the vertices, but they are not accessible when drawing in the sketch mode.
I could probably use the measurements of the grooves and the separation between the two grooved boards, but the idea is to use the existing components as reference points so I don't have to recalculate every thing.
Thanks!
I don't know if the attached project file will show the issue.
davebYYPCU
Try Sketch > Project tools.
You need to bring existing external geometry, into the current sketch - to be able to snap to these projected articles.  Sometimes they are purple, sometimes invisible.
Try Thin Extrude after stream lining the amount of sketching.
Might help….
paulGJCBP
Thanks. Hope I don't appear too dense by I don't see the sketch>project tools menu item.
g-andresen
active sketch mode > CREATE > PROJECT > project or shortcut P
günther
paulGJCBP
Yes, I see that now.
1) Even though I now can see the projected vertices of the groove cross section, the rectangle tool does not snap to them - ignores them.
2) The top of the panel mates with the top grooved board and the bottom of the panel mates with the separate bottom grooved board.  I need to snap to the vertices of grooves of these two separated boards.  There is no common surface and doesn't project to a construction plane that includes the top and bottom.
See attached image
jhackney1972
See of this video helps.  Model is attached.
John Hackney, Retired
jhackney1972
Did my video answer your questions?  If not, let me know, If so, please select Accept Solution on my post.
