Hello All,
I had the exact same problem and I can say this about it:
Reason: Need updated graphic drivers.
It probably happens with the in-built Intel graphics.
When automatically searching and installing the latest drivers, it didn't work!
It is important to do the following steps (after you know your graphic card model):
1. Download the Latest Driver:
1.1. (If you are with Intel graphic) Visit the Intel Download Center website: https://downloadcenter.intel.com/
Use the search function to find the latest driver. You may need to enter your processor model or use the auto-detection tool provided on the website.
1.2. Download the latest driver for your operating system.
2. Uninstall the Existing Driver:
2.2. Press the Windows key + X and select "Device Manager" from the menu.
2.3. In Device Manager, expand the "Display adapters" category to reveal the graphic card.
2.4. Right-click on it entry and select "Uninstall device".
2.5. Check the box that says "Delete the driver software for this device" if available.
2.6. Click "Uninstall" to remove the driver.
3. Restart Your Computer.
4. Install the New Driver:
4.1. Locate the downloaded graphics driver file.
4.2. Run the installer and follow the on-screen instructions to install the new driver.
5. !!! If prompted, select the "Custom" or "Advanced" installation option to perform a CLEAN installation.
During the installation process, make sure to select any options related to performing a clean install or removing previous driver versions.
6. Restart Your Computer to apply the changes
Good Luck!
