data panel does not show - error message while launching Fusion
alderson.eric.j
alderson.eric.j
When launching fusion, I receive twice the following error message : "C/User/alder/AppData/Local/Autodesk/webdeploy/production/22e664d43fce268ac9bf1fa1cda69e49585c997/Win64/AdCefWebBrowser.exe : Path does not exist" (screen capture joined).
When clicked OK, Fusion opens but the data panel does not appear (instead a blank white space). I still can access my files via the "File-Open" function but this is annoying when I need to assemble several files created separately to make a full design.
I tried launching again the application, resetting the display... nothing does work.  I run it under Windows 10 and here are the specs of my laptop :
Aspire A517-51G
Intel Core I7-8550U CPU 1.8 gigahertz.
8 gigas RAM
Video : Nvidia Gforce MX150
Can someone tell me what I need to do ?
Thanks in advance,
Eric.
RajkumarIlanchelian
@alderson.eric.j @While Fusion is launching press Ctrl+Shift to launch the Fusion service utility. Run a repair from here to see if that helps.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
alderson.eric.j
Thanks for the tip. It worked like a treat ! I'll have to remember this for
the next time this happens
alderson.eric.j
thanks for the solution. It worked perfectly.
Eric.
Thanks for the tip. It resolved the issue perfectly. I'll have to remember it for the next time this happens.
Eric.
truonggiangnk
Community Visitor
Community Visitor
Holy cr!! Thank you so much. It works!!!
