Data Panel blank after update.
gus.grubba
Message 1 of 22
gus.grubba
Data Panel is blank after the last update. I can load models from the file menu, although the application keeps freezing every now and then when doing anything.
Replies (21)
Message 2 of 22
gus.grubba
Replying my own post. After "Repairing Fusion 360", full uninstall and reinstall, nothing worked. After noticing a pattern in similar posts with this issues, on a hunch I "signed off" and signed back in. The panel was restored. Note that while blank, I was still able to load my projects using File/Open 🙄
Message 3 of 22
e9_vito
I'm having a similar issue and no matter what I do, my data panel will not load....
Message 4 of 22
gus.grubba
Yup, there is something messed up with it. I did first solve it by login off and then back in. But I now realize I have to do that every time I launch Fusion. Each time I launch, it's blank, requiring the log off/on cycle.
Message 5 of 22
e9_vito
Anyway for you to unmark this as solved so we can get some eyes on this? I only have an educators license so I can't message support unfortunately.
For reference, I have no issues on my mac studio, or macbook, which are also running the latest version of MacOS. Logging off, uninstalling, reinstalling, nothing works.
Message 6 of 22
gus.grubba
No, I could not find a way to undo the "solved" flag. I have not tried this on my laptop yet (M2). This is happening on my desktop machine (Mac Pro 2019 - x86).
Message 7 of 22
e9_vito
Ahhh I left that out. This is happening on my 2019 mac pro as well. I assume it's something related to the graphics card and the latest update then....
Message 8 of 22
john.koerner
I removed the solution checkmark. Can either of you share your diagnostic log files to help our team diagnose this issue further?  https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-and-sh...
John Koerner
Message 9 of 22
e9_vito
Here you go John. Thanks!
Message 10 of 22
john.koerner
@gus.grubba Would you be able to provide your logs as well? We are trying to diagnose the problem and another set of logs might help find the common issue here.
John Koerner
Message 11 of 22
gus.grubba
I had tried uploading when you first asked but I kept getting: ".zip" files not allowed.
Anyway, it worked now. See attached.
Message 12 of 22
nilesh_kuber
Hi Guys,  can you try following command and let us know if this is fixing issue:
DataPanel.url /default
If this won't fix this issue, please help us with following steps:
1. Give DataPanel.status command
2. Step 1 will return path of "data_view_rel.html". If possible can you send us screenshot of contents of folder where "data_view_rel.html" present.
Thanks in advance !!
Message 13 of 22
gus.grubba
Nothing changed when running the command other than showing the path as you mentioned:
DataPanel URL : file:////var/folders/vt/ysdcsvzj1nq0tn6n3wf1f_ym0000gn/T/Neutron/0f5cc672-14a6-4638-975e-bd9c493b031c/data_view_rel.html
The contents of that folder:
~ % ls -l /var/folders/vt/ysdcsvzj1nq0tn6n3wf1f_ym0000gn/T/Neutron/0f5cc672-14a6-4638-975e-bd9c493b031c
total 9488
-rw-r--r-- 1 gus staff 2252625 Dec 6 10:01 OfflineJS.zip
drwxr-xr-x 311 gus staff 9952 Dec 6 10:01 assets
-rw-r--r-- 1 gus staff 572 Dec 6 10:01 blocked_client_view_rel.html
-rw-r--r-- 1 gus staff 522 Dec 6 10:01 blocked_os_view_rel.html
-rw-r--r-- 1 gus staff 28185 Dec 6 10:01 create_branch_rel.html
-rw-r--r-- 1 gus staff 27394 Dec 6 10:01 create_milestone_rel.html
-rw-r--r-- 1 gus staff 209782 Dec 6 10:01 dashboard_rel.css
-rw-r--r-- 1 gus staff 1744430 Dec 6 10:01 dashboard_rel.js
-rw-r--r-- 1 gus staff 2729 Dec 6 10:01 data_view_rel.css
-rw-r--r-- 1 gus staff 330 Dec 6 10:01 data_view_rel.html
drwxr-xr-x 12 gus staff 384 Dec 6 10:01 font
-rw-r--r-- 1 gus staff 96380 Dec 6 10:01 jquery-1.11.0.min.js
-rw-r--r-- 1 gus staff 407099 Dec 6 10:01 manage_rel.html
-rw-r--r-- 1 gus staff 49443 Dec 6 10:01 merge_rel.html
-rw-r--r-- 1 gus staff 9584 Dec 6 10:01 simple_sharing_public_link_rel.html
Message 14 of 22
nilesh_kuber
Thanks a lot. We will analyse this further.
Message 15 of 22
nilesh_kuber
Just one small help, can you run "Dashboard.getversion" command and let us know result of that. Thanks !!
Message 16 of 22
gus.grubba
Here we go:
Dashboard.GetVersion
v2.0
Message 17 of 22
e9_vito
Sorry I haven't been at my mac pro for a bit, but back and still having the same panel not showing. Where or how do I run that DataPanel.url /default command?
Message 18 of 22
anurag_naik
You can run the DataPanel.url /default command on the Text commands panel (File options --> View --> Show Text Commands).
We are currently investigating to re-produce this issue on our end on priority, meanwhile could you please check if the steps mentioned for Data panel is white in solutions section of this doc help resolving the issue.
Message 19 of 22
e9_vito
I went to go gather the info and my data panel was working. Since it was, I did not run the default command and just grabbed the other output.
DataPanel.status
DataPanel URL : file:////var/folders/qr/9z5cyp3s02x9z812whn8cm880000gs/T/Neutron/d8ce5e47-ad43-4033-be20-9390eaf6703c/data_view_rel.html
v1.0(legacy)
ls -l /var/folders/qr/9z5cyp3s02x9z812whn8cm880000gs/T/Neutron/d8ce5e47-ad43-4033-be20-9390eaf6703c/data_view_rel.html
-rw-r--r--  1 ciancia  staff  330 Dec 12 21:41 /var/folders/qr/9z5cyp3s02x9z812whn8cm880000gs/T/Neutron/d8ce5e47-ad43-4033-be20-9390eaf6703c/data_view_rel.html
more /var/folders/qr/9z5cyp3s02x9z812whn8cm880000gs/T/Neutron/d8ce5e47-ad43-4033-be20-9390eaf6703c/data_view_rel.html
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
    <link rel="stylesheet" href="dashboard_rel.css" type="text/css" />
    <title>Data View Application</title>
    <script src="dashboard_rel.js"></script>
</head>
<body onload="DataViewApplicationStart();">
</body>
</html>
Message 20 of 22
gus.grubba
Between then and now, I formatted my boot disk and reinstalled everything from scratch. I just finished installing Fusion and it all seems to be working. Same computer, no change in hardware. Just a fresh install of the OS (I had wiped Fusion and reinstalled it earlier, before this radical move, with no changes). I also noticed that with this new install from scratch, I ended up with a new version of Fusion so I can’t tell what fixed it.
