Cut in second curve
Cut in second curve
damjanRBUXA
Message 1 of 18
Cut in second curve
damjanRBUXA
How can I cut this form start to the end as it is marked?
because when I try to cut it goes straight down.
Replies (17)
Message 2 of 18
TheCADWhisperer
@damjanRBUXA
Sweep rather than Extrude.
But your circle is blue?
Message 3 of 18
damjanRBUXA
ok what is difference between sweep and extrude? sorry for dumb question?
here it is
forum doesnt allow me to add 3mf file so I had to make it as zip
Message 4 of 18
TheCADWhisperer
I didn't request a 3mf file.
I specifically requested a native fusion format file *.f3d
Message 5 of 18
damjanRBUXA
ok here is a file
Message 6 of 18
jhackney1972
To create your cut feature I used a Sweep.  The video will explain.  Your model is attached.
John Hackney, Retired
Message 7 of 18
TheCADWhisperer
@damjanRBUXA
Edit Sketch1.
Drag the blue circle...
Missing two Coincident Constraints.
Add the two missing Coincident Constraints.
What color is the circle now?
Message 8 of 18
TheCADWhisperer
@damjanRBUXA
My guess is that you actually want the Sweep cut profile Perpendicular to the Path. See Attached.
(Revolve could also be used for this.)
Message 9 of 18
damjanRBUXA
that circle sohould be on points at 15 mm and 45.5 mm
In my case there was. what to do next time to stick that on those points?
Message 10 of 18
damjanRBUXA
thank you it is a bit complicated but I will manage it.
Message 11 of 18
TheCADWhisperer
But not constrained to those locations.
Note that the circle was still blue.
Blue curves should keep you awake at night.
Simply add the two missing Coincident Constraints.
That way if you change ANY of the dimensions - EVERYTHING will update correctly and predictably.
Click on image above to enlarge the view.
Message 12 of 18
TheCADWhisperer
I did my Profile Perpendicular to the Sweep Path.
Message 13 of 18
TheCADWhisperer
Extrude is in a straight line perpendicular to the Profile.
Sweep follows any defined Path (in this case your arc).
Message 14 of 18
TheCADWhisperer
Would you like to see the easy way?
First, make use of Symmetry about the Origin.
Use Extrude Symmetric (midplane) for your first Extrude.
Message 15 of 18
damjanRBUXA
I see now it is black circle
Message 16 of 18
damjanRBUXA
ok I did it, what is next?
Message 17 of 18
TheCADWhisperer
@damjanRBUXA
As I started to show another technique it occurred to me that the second circle might not be positioned to achieve the correct geometry.
What are you modeling?
What does the mating component look like?
Message 18 of 18
damjanRBUXA
I finally manage to make this to get what I wanted.
this is a holder for a registration table on the back of motor bike TOMOS.
If anyone need it here it is.
