Customizing environment(s), xml location
jordy_keller
jordy_keller
I used the method of editing the xml for photobooth before to prevent the extremely flashing highlights. See this post: https://forums.autodesk.com/t5/fusion-design-validate-document/customized-environment-colors/m-p/132...
I don't exactly remember how I found the right xml back then.
Now I'm in the new dark blue theme and I have selected the theme default environment:
My question is: How do I find the xml for this environment?
If I go to C:\Users\UserName\AppData\Local\Autodesk\webdeploy\production
I find 20+ folders with random names containing a total of 82.532 files...
Thanks.
g-andresen
You have to search for the latest ones and the folder that contains "Neutron" among others.
If you insert your own XML, you must be aware that it will not be adopted in the next update and must be inserted again.
Günther
jordy_keller
Ok, thanks.
I'm writing a python script that will give me the most recent folder in which the xml files are located
- list directories in C:\Users\UserName\AppData\Local\Autodesk\webdeploy\production
- sort by date modified in descending order
- search the list and return the most recent folder that contains
Neutron\Server\Scene\Resources\Environments
I can then find and edit the xml file for the environment or have the python script do that for me.
That shouldn't be a problem for the known/named environments (like darksky, greyroom, photobooth etc)
However, I like the new dark blue theme but I do not know which environment xml it uses.
The selected environment being:
How can I find that out?
Thanks.
jhackney1972
I find the River Rubicon Environment to be the exact same screen color as the Theme (Default) you show in your screen capture.  With this, you can use the same path your used before and simply modify the River Rubicon Environment.
John Hackney, Retired
jordy_keller
Ok, yeah, it does indeed seem like "Theme (default)" is 'River Rubicon'
I got my script working:
https://forums.autodesk.com/t5/fusion-support/dark-mode-and-customizing-highlight-colors-to-prevent-...
I'll post question regarding this topic and findings over there from now on.
