Custom Sheet Size not working
mathieuD8XG3
mathieuD8XG3
I am running fusion 360 on MAC OS and with the new update i should be able to set custom sheet sizes. I want to create an oversize A0 (1118mm width x 3000 length).
But when filling in the width and length and pressing OK the size changes back to its original value.
Ruby4_test
Hello @mathieuD8XG3 ,
I saw your video and tested it at my side, I am unable to reproduce the issue, please send me the file which you are facing the issue with. Meanwhile, can you please try the steps mentioned below and see if this solves your issue?
  1. Restart Fusion by saving and closing the drawings and other files which you are working with
  2. Now create a drawing and when selecting the sheet size select custom in create drawing dialog and add the desired values here
  3. You should get the custom sheet here. Also you should be able to change the sheet size when in drawing workspace.
Pramod.kadam
Hi @mathieuD8XG3 ,
Apologies that you are facing an issue.
Can you please confirm if you have AutoCAD for Mac installed on your machine or you have created custom sizes using any other applications on the same machine?
If yes, check if following workaround resolves the issue.
In Mac: Open TextEdit > File > Page Setup > Click on Paper Size > Manage Custom Size > Select all Size Entries and Remove them.
Thank you,
Pramod Kadam
Product Owner
Fusion 360 Drawings
