Curved loft issue and broken 3D print Export
Since the latest update, several features have stopped working.
In addition to long-standing bugs, like the broken timeline where objects disappear and only reappear when going back and forth, there are new issues with T-splines.
When I attempt to join two faces with a loft, the result is curved instead of a straight line, eventhough the setting is "connected". The setting "tangential edges" at the bottom of the window doesn't seem to have an effect at all. I haven’t found a workaround, and chamfering doesn’t work for this shape. In the previous version, everything worked as expected as you can see in the first picture.Before the update
After the update
Another issue is exporting objects to 3D slicers. I can only send an object to a slicer (Bambu Studio) if the slicer was closed beforehand, which forces it to open a new document. After that, I can't add more objects to the same file. My current workaround is exporting each object to .stl and then manually importing them into the slicer, which is time-consuming. This used to work flawlessly before the update.
Please roll back the previous version, as the new one seems inadequately tested and has made the software unusable. The T-spline issues are especially problematic, as the shapes it produces can’t be printed.
Thank you for your attention to this matter.
