Cropped perspective view on change of scale
jameswVTJ5V
jameswVTJ5V
Hi all,
I have a perspective view in a drawing which displays fine when initially created...
However, if I change the scale it is cropped....
And ends up like this...
Any ideas why this might be a thing? It only seems to happen in the front perspective view and with this particular model.
https://a360.co/41eMnmG
TIA
jhackney1972
You have your Focal Length set to Narrow in your Prospective View.  Change this to Wide or create a new scaled view before changing the view to Prospective View will help you out.
John Hackney, Retired
jameswVTJ5V
@jhackney1972
Thank you for your reply.
Unfortunately choosing wide focal length doesn't seem to make a difference.
So this is the perspective view created at the native scale (1:50) and with wide focal length...
And this is it scaled to 1:30...
And this is the result...
Also I may be missing something, but how do I create a standard view and then change it to a perspective view?
Cheers!
jhackney1972
The attached video will give you are workaround to your problem.  It is not a solution but will get you going.
If this gives you a solution to your question, not to the Fusion problem, please select the "Accept Solution" on my post.
