creating drawings from an assembly. Fusion Crashed, and now fusion will not open the "recovered" file.
Splitray
Observer Observer
Splitray
Observer
Observer
I created a file that has a bunch of components and started to create drawings of the components. Just a bunch of sheet metal parts that have bends. NOTHING difficult or complex.  Fusion 360 Crashed and when I tried to reopen the file I was working on, I get two warnings.
This is the first one. Nothing too bad. I figured it was just a couple of hours of work Nothing I haven't had to deal with before when working in fusion 360.
But then, when I hit the OK to open the file, I get this Error.
I cannot open the file, so I go to the previous version of the file, figuring that I would be able to open it and then save over the latest version.  BUT the latest version I can only do a save as and cannot save over. So now all my drawings and their links are useless and cannot be updated or corrected.
Unless someone has a recommendation.
CGBenner
@Splitray
Welcome to the Community!  I moved your post here, as this is a better forum for getting advice on error messages such as these.  Good luck!
Chris Benner
CGBenner
@Splitray
Hi, do you still need help with this?
@RajkumarIlanchelian any thoughts?
Chris Benner
RajkumarIlanchelian
@Splitray When you open a previous version and go into File- are you not seeing save as latest option?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
CGBenner
@Splitray Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
