Creating drawing with template - is there away to turn off auto sheet creation??
crueby1
crueby1
When creating a drawing from a model, if I create 'from scratch' it just makes a single page, then I can add more manually as needed. When creating a drawing using a template I created, it makes one page per component in the model, whether I have 'Automatic' or 'Manual' selected in the create dialog. Is there a way to tell it NOT to do one page per component? Many times I want to just do the full model as one assembly on one page.
ClintBrown3D
Hi @crueby1
It sounds like you are using a "Smart Template". This is any template with pre-defined views or sheets.
Deleting the browser nodes, views and sheets, will give you the behavior that you are expecting.
image-2
Take a look at this link, for more info on how to convert your template to a normal template:
https://clintbrown.co.uk/2024/02/26/fusion-drawing-automation-template-options/
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
crueby1
Perfect! That did the trick, thanks very much!   The help pages around the drawings/templates could really use an update to explain the workflows better!
