creating an arc ring (jewellery)
navpat
Message 1 of 8
navpat
hi all,
i've been trying to creating this ring but everytime i revolve a rectangle (1mm x .5mm) it offsets at a weird angle. im trying to make 2 cuts. one for the top arc and one for the bottom. please help me out. i've attached the fd3 file
thanks in advance!
Replies (7)
Message 2 of 8
ryan.bales
Autodesk Support
Autodesk Support
The main issue is that the rectangle drawn in your sketch is offset of the sketch plane (its a 3D sketch). This makes it off of the center axis/plane used when revolving the body. Screen Shot 2022-02-03 at 1.31.32 PM.png
Ryan Bales
Fusion 360 Product Support
Message 3 of 8
ryan.bales
Autodesk Support
Autodesk Support
The quickest fix is to edit the sketch, select the rectangle and right click, then pick 'move to sketch plane'
An observation - this design is full of unconstrained sketches. It would be wise and prudent to define them fully!
Ryan Bales
Message 4 of 8
navpat
there's no option for that. what can i do? can you show me in the fd3 file please?
Message 5 of 8
KristianLaholm
I cleaned up unused sketches and draw the arcs in sketch with dimensions.
Emboss the arcs and then used revolve on 2 faces.
I hope I got your design intent correct?
Message 6 of 8
navpat
yes! that's exactly it! how did you do the revolve exactly? did you revolve a rectangle? please and thank you
Message 7 of 8
KristianLaholm
I used 2 faces created by the Emboss feature (yellow in image bellow).
And set the Revolve angle less then 360deg to not cut away the "arc-design"
Message 8 of 8
navpat
ah ok! thank you so much 🙂
