Creating a surface
Creating a surface
dsj013
Creating a surface
dsj013
I have two curved lines and I am wanting to make a surface between them where the surface follows the curve paths. There is a feature on Siemens NX CAD called 'Through Curves' which does this but I am not sure if Fusion can do this?
Dalip
davebYYPCU
Surface > Create > Loft
select the curves.
Might help….
dsj013
Thanks for the response. I have attached a image of the two curve I am trying to create the surface between. Its hard to see but the Blue line is not in the same plane at the other line if that makes sense.
dsj013
When I use loft it tried to do what I am trying to achieve but the surface don't nicely close and instead intersect.
jhackney1972
Attach your model, not just a screen capture.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
dsj013
Sorry I have attached the model.
davebYYPCU
You didn't say they were projected curves, that are not coincident joins.
The blue curve works as expected the purple curve is a series of short curves.
No timeline, can't fix it.
Might help....
