Creating a mold from a customer part file by using combine, (cut from) and then split the mold
Let's start by saying that we have successfully performed the needed actions to get most of our desired results. Most being we have created a mold that has subtracted our customer's part file from withing the internal contents of this 3d box. What we have not discovered is a way to make a "clam-shell" mold from our part file.
1. We converted our customer part file to a mesh object
2. Created a simple 3d box for the mold and converted that to a mesh
3. Then we used the "combined" feature to cut the part volume from this 3d box
4. We then split this "mold box" into two halves
5. We used section analysis to move a face back and forth to verify that the contents of our customer part file had been subtracted from our 3d box.
Great this works but we need a mold that is split by using the upper surfaces and the lower surfaces. A forming mold not a fill mold.
I used to work in a progressive die design environment to develop steels that would form our part - although with another software. We started this process by separating the outer skin of the part from the inside skin of the part. Metal thickness was at maximum 1mm. We then projected our steel (3d box) up or down to meet these separated skins, this creating a steel that would give us an exact copy of our form.
Without knowing another path in Fusion to take with our existing project, can this be accomplish with Fusion 360 by projecting a solid to our part step file without separating the outer and inner skins? Would we have to separate the upper and lower surfaces at all? Or is there another way to do this?
We are not asking someone to design our mold for us - just asking for some help on the methodology to get this task done. The current designer is using another CAD package but i have insisted all along to our customer that Fusion 360 can do this.
A part file is attached to this message. Any help or direction would be appreciated.
Thank you,
John
