Crashing when using dimension tool.
sailordan.coyote
Message 1 of 11
sailordan.coyote
Fusion keeps crashing on me now that my design is getting slightly larger and complicated.  Still pretty small though, only four components.
I have done a clean reinstall of my NVIDIA drivers and of Fusion 360.
Open to any other suggestions.
Screenshot attached.  This has happened probably over 20 times this weekend and I am unable to move forward with any of my work.
Dan
Replies (10)
Message 2 of 11
sailordan.coyote
I believe I have fixed the problem.
I should have gone to the Autodesk page first.  Because the solution was right in front of me.  I read it last night but was too tired and inexperienced to know where to change the setting.
I have enabled DirectX 9 in preferences and everything seems to be functioning as usual.
Message 3 of 11
sailordan.coyote
So I have most definitely not fixed the problem.  Fusion is crashing very frequently and just running like a bag of crap in general.
My PC should be plenty powerful enough to do the very small stuff I'm doing.  I would have thought I'd be good to model up to 500 parts.
I don't know.
Message 4 of 11
jeff_strater
can you share your design?  This sounds like a data-specific issue.
Jeff Strater
Engineering Director
Message 5 of 11
sailordan.coyote
https://a360.co/2KRJjXi
The crashing seems to happen when I am trying to define sketch dimensions or add constraints.
I have had Fusion turn unresponsive for a few seconds then regain its composure, through to crashing directly to the desktop.
I will nearly always get the black screen like in the screenshot from the first post.
I have included screenshots of my dxdiag to show you the drivers etc I am using.
Thanks for your help!
Message 6 of 11
steffen.eckardt
Good evening,
i am experiencing the same issue when tring to edit dimensions of a previously finished sketch. When I am working on a new sketch, it doesn't seem to be a problem. It also seems, only changes to certain constraints are critical, especially when the profile/contstraint is a dependency for a later operation, like e.g. an extrusion.
My personal guess would be, that the recalculation of dependend properties or parameters is somehow faulty.
Steffen Eckardt
P.S.: I will attach a screencast as soon as it is uploaded and changed to public.
Message 7 of 11
jeff_strater
@sailordan.coyote - thanks for sharing the design - always helps in debugging.  We are investigating a crash/hang in Fusion related to sketch dimensions.  Can you provide some more details here about which sketch you are editing, and what type of edit causes the hang?  Thanks.
[edit] I see from the original image that you are editing sketch1 in "end frame drive end", but it would be good to know what specific operation you are trying in that sketch which fails.  Are you adding  a new dimension, editing an existing one, or what?  Thanks.
Jeff Strater
Message 8 of 11
sailordan.coyote
Hi Jeff,
Sorry for the delay each time.  I'm in Australia and Uni is on holidays, which means I only get to a computer once a day.  Bear with me.
I went into my design and was able to crash the program straight away.  Screenshot attached.
I was editing "End frame drive end:1".  I clicked Create Sketch and then chose the face that is the mounting flange for where the stepper motor would mount.  I created a circle then hit concentric and constrained it to the existing circle.  Fusion really didn't like it when I did that.  I'm not sure if I should be using the project feature when I do stuff like that?  But I feel it should be able to predict what I'm trying to do there.  Anyway, that's when it crashed.
Fusion stayed unresponsive for around five minutes and then came good.
Most of my problems have been through adding dimensions or constraints.  Other than the problem above I can't recall precisely my other crashes.  I will endeavour to take more notes and get back to you.
Cheers,
Dan
Message 9 of 11
jeff_strater
thanks, @sailordan.coyote .  I'm able to reproduce a definite slow behavior in sketch.  I don't see a crash, but it is slower than I would expect:
Does this accurately capture what you are seeing?
Jeff Strater
Message 10 of 11
sailordan.coyote
Hi Jeff,
Yes it is similar behaviour to what I am experiencing.  But that's not it 100%.  I wonder if your extra RAM helps Fusion power through those glitches whereas I get a half black screen and a crash.
I used Fusion for about two hours last night inside of the main design you have access to.  I had one or two small crashes where I got the half black screen and then everything came good.
I spent the rest of the night modelling a different component and had no problems with Fusion other than my own clumsiness.
I'll keep you posted.
Message 11 of 11
LishuangLu
@sailordan.coyote, the performance with adding dimensions or constraints has been addressed recently. Please feel free to have a try and let us know if there's any feedback.
Thanks for your support!
-Lisa
